Changing Route Patterns drops call on the gateway?
Answered Question
Feb 26th, 2009
  • Green, 3000 points or more
If the gateway is MGPC, and the Route Pattern destination is directly to the gateway PRI, will it drop calls currently in progress if we update the pattern?
If the Route Pattern pointed to the Route Group/Route List, it should not reset the gateway correct?
Thanks!
Correct Answer by gogasca about 8 years 4 months ago
For 1 and 2, Yep thats the intended behavior.
Are you obeserving something different?
Which cucm version
Overall Rating: 5 (1 ratings)
Correct Answer
gogasca Thu, 02/26/2009 - 12:25
Which cucm version
Tommer Catlin Thu, 02/26/2009 - 12:28
I wanted to confirm the behavior was correct. The SRND or config docs online did not state anything. Trying to narrow down if i could make changes during the day depending on how the RP's were setup.
Thanks much!
