The incoming calls get to agent automatically,no answer button?
Hythim Ali El Hadad Thu, 02/26/2009 - 14:37
IF you need you agent to be in aready state after login automatically
It is not available in IPCC Express.Agent needs to set themselves in the ready state after logging in.
Best Regards
I menat was:
The agent is already Login, when the agent receives a call, he does not need to push the answer button, the customer needs that the call is answering by the agent automically without pushing the answer button on Cisco IP Communicator.
Walter Flores
Jonathan Schulenberg Thu, 02/26/2009 - 15:51
That's not up to UCCX. You can configure auto-answer on the Directory Number appearance within UC Manager.
+1 on the above post. Log into your CallManager and go to that person's device and into there directory number and you should have an option for Auto Answer under Directory Number Settings. Set that to enable.
If you only wanted auto answer setup for IPCC calls that come in then you would have to create another Directory number on the phone and associate IPCC with that extension so only IPCC calls go to that extension and only set that to Auto Answer instead of the main line.
Hi thanks for answering,
I will use your suggestion, but I was wondering how the IPPC-X will be handled the NOT READY state, because it is configured the agent does not answered, the IPCC-X change the agent state from READY STATE to NOT READY STATE, I think the IPCC-X does not realize of it any more??
Any Idea
Jonathan Schulenberg Sun, 03/01/2009 - 09:03
First to follow up on [email protected] comment: You will almost always have a separate directory number for the ACD line. This is because ACD lines are not allowed to have call forwarding (no voice mail) and should be modified to lower busy and maximum call values per the UCCX documentation.
If you set auto-answer on the directory number line appearance, the IP phone will go off-hook after one ring on incoming calls. UCCX has no way of knowing this is any different from the user pressing 'Answer' on their phone and renders the "Agent State after Ring No Answer" system parameter useless.
