DHCP address relay
Feb 26th, 2009
Hi all,
As of recent i have put in these cisco 1812's and configuring them so they have remote vpn access enabled. For this i configure a dhcp relay on the internal interface and then use the "crypto isakmp client configuration group [NAME]" command to configure the DHCP settings.
The last cisco i tried was an 1841 and it did not have the DHCP command, so i am unable to set the giaddr or DHCP server. Does anyone have any idea why i cannot use these commands ?
(I have disabled DHCP server as well on the router)
Nathan
drolemc Wed, 03/04/2009 - 17:37
  • Silver, 250 points or more
Try this DHCP configuration.
router>enable
router#config t
router(config)#service dhcp or router(config)#ip bootp
router(config)# ip dhcp pool TEST
router(dhcp-config)# network X.X.X.X Y.Y.Y.Y ( ip address and subnet
mask that the LAN will use )
router(dhcp-config)# dns-server {ip of dns1} {ip of dns 2}
router(dhcp-config)# default-router Z.Z.Z.Z ( internalip address of the router)
router(dhcp-config)#ctrl-z <----to exit
router(dhcp-config)#ip dhcp excluded-address
To use a remote dhcp server
router>enable
router#config t
router(config)# ip helper-address x.x.x.x <---- ip address of the
remote dhcp server router(config)#exit
