NO NAC redirect page using VPN SSO + ACS in inband Virtual Gateway
admin_2
Level 3
Level 3
Daniel Laden
Level 4
Level 4
the web redirect is used to login. Since you are using VPN SSO, you do not get prompted to login.
-Dan
hI Dan,
Yes, I agree whit you.. in case VPN SSO auth shows a authenticated user.
ON the NAM VPN SSO online list,(vpn users authetication through ACS server)I can`t see any VPN client user authenticated.
The issue is :
The VPN client authenticate fine and get an IP address from the VPN concentrator. Then the client try to open a Intranet WEB page (This traffic must to pass through the NAS) and the NAS is not redirection the NAA (first time) or popup the previusly locally installed NAA.
It seems the NAS can`t see the DIscover traffic.
I TRIED USING REAL IP GATEWAY and everything works normally, BUT WHAT COULD BE happening whit the VIRTUAL GATEWAY topology ?
I will post both topologies, but this plattform doesn`t has the option to attach.
How can I send to you the topology ?
Lets start by confirming the pathway is good. Allow all traffic in your unauthenticated role and confirm you can access the inside network via VPN.
You will need to provide your attachments here for the benefit of the community. There looks to be be an 'add attachement' link below the posting window.
