WLC reset - then odd behavior
Feb 26th, 2009
I had this occur on two 4402's in 1 week. Unexpected system reload based on uptime although no crash log, controller will not associate any NEW clients, existing clients OK, controller reports erroneous client count. Then after rebooting the controller it functions normally. At first I was thinking failed power supply caused issue as PS1 did go red, now not sure. TAC has no idea as well - just wondered if anyone had experienced this odd behavior. 4402 - v.4.1.185.
Stephen Rodriguez Thu, 02/26/2009 - 17:01
  • Purple, 4500 points or more
as you have a TAC case open, I don't want to step on the toes of your engineer.
But, I would upgrade away from 4.1 up to 4.2.176.0, there are many bug fixes, some of which are for memory leaks.
HTH,
Steve
George Stefanick Thu, 02/26/2009 - 18:51
  • Community Spotlight Award,
    Best Publication, October 2015
We just had this same very issue 4.1.185 and we worked with TAC and went through the motions of upgrades to 4.2.x. We ended up RMAing the WLC as it continued to work fine for a few weeks and them nut up again....
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
