02-26-2009 05:00 PM - edited 03-06-2019 04:17 AM
Hey...
I've got a SupIV that wont boot the image. Config register is 0x2102.
From ROMMON, I can give the boot command with image name, and that gets me to IOS.
The BOOT variable, as displayed by "set" in ROMmon, is the correct filename for the image in bootflash:.
There's only one image in flash.
It makes no difference whether or not I configure boot system flash in startup-config.
I ran the verify command on the image file, and it verified.
The message is "Could not find a valid file in BOOT environment variable"
Anyone know of anything else I can do to get this switch to boot the image?
Linnea
Solved! Go to Solution.
02-27-2009 09:58 AM
Try changing the config register to 0x2101 , this will allow it to boot the first image it finds in flash without a boot statement. Whats the exact boot statement you are currently trying to use. ? Should be like this
boot system flash bootflash:cat4000-i9k91s-mz.122-25.ewa4.bin
02-26-2009 07:07 PM
What is the complete model number of your Sup card and what is the image filename? Is it a compact flash?
02-27-2009 08:52 AM
WS-X4515
cat4000-i5k91s-mz.122-25.EWA3.bin
bootflash, not compact flash, as in:
Switch#dir
Directory of bootflash:/
1 -rw- 13017844 Sep 18 2005 19:19:24 +00:00 cat4000-i5k91s-mz.122-25.EWA3.bin
02-27-2009 09:58 AM
03-03-2009 03:13 PM
Hi Glen,
OK, I'm now good.
0x2102 booted to IOS.
And my boot command was missing the device designation (i.e., bootflash:)
And, once I fixed the boot command, it now boots to IOS with config reg at 0x2102.
Thanks!
03-12-2009 03:33 PM
i have the same issue,
6513-01#show start | inc boot
boot system sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin
6513-01#show run | inc boot
but while i run diagnostic sanity, comes up with invalid boot image. cat6500 with sup720.
1118th307-6513-01#show diagnostic sanity
Pinging default gateway 192.168.30.1
Sending 5, 100-byte ICMP Echos to 192.168.30.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Invalid boot image "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin," specified in the boot string.
Please check your boot string.
None of the images specified in the boot string are valid.
Please specify at least one valid image in the boot string to ensure the
switch is in a bootable state.
Invalid boot image "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin," specified in the boot string on the slave.
Please check your boot string on the slave.
None of the images specified in the boot string on the slave are valid.
Please specify at least one valid image in the slave boot string to ensure the
slave is in a bootable state.
Please provide me the details. Thank you.
