CatOS
naveen_b81 Thu, 02/26/2009 - 22:05
set vlan 50 0/15
Here i have assumed 0/15 is your port number.
Kerem Gursu Fri, 02/27/2009 - 01:01
Hi Hunt,
You can use
set port host
which will set your port to access mode and perform portfast. After doing this , you can assign the correct vlan to your port.
Hope to help,
Kerem
glen.grant Fri, 02/27/2009 - 05:15
  • Purple, 4500 points or more
You can also use set trunk slot/port off " I believe. This makes it a access port.
