UNITY 5.X ON BOX FAILOVER
Feb 27th, 2009
we are adding languages to the above configuration, should we down the secondary server while we add lanuages to the primary (if so then we won't have a domain to login to) and similarly should we down the primary while we upgrade the secondary?
(previous versions 3.x and 4.x failover guides do state that we should but the modifying 5.x with on box failover does not specifically state that).
Also is there an es65 anywhere, I can see ES65 rollup under unity s/w on Cisco but do i need ES65 before applying roll up?...cheers
jeff
