stickiness using JSESSIONID
Feb 27th, 2009
I was wondering if anyone can give me some configs for making stickiness work by using JSESSIONID on CSS and ACE. If we don't know the exact value for the string from the server can we use offset or hash on ace and css? and if so how do u do it?
Gilles Dufour Fri, 02/27/2009 - 06:36
thanks for posting your question on the forum.
The CSS does not have the possibility to learn dynamic cookie value created on the server.
So, you can either use arrowpoint cookies which is quite simple or have your server team add a static value to the jsessionid in order to identify the server.
We can then configure the CSS to locate this static value and match it to a service.
The ACE appliance/module has the dynamic cookie feature.
You then just need configure the cookie name and the box does the rest.
