02-27-2009 07:21 AM - last edited on 03-25-2019 03:22 PM by ciscomoderator
According to my reading of hardware compatibility guides, the HWIC-1FE should work in the 28xx routers. However, I'm having a problem with it in 2811's. I've tried two different HWIC-1FE's in different slots of two different 2811 routers, and get something like this at bootup:
%GT96K_FEWAN-1-UNKNOWN_WIC: NM slot 0, wic card has an unknown id 53Asslinit fn
Am I misintepreting something here?
Solved! Go to Solution.
02-27-2009 07:52 AM
As i say you need a 12.4T version of software. You have a 12.4 version. The hardware support for the HWIC-IFE for the 2800's was added in the T train.
Jon
02-27-2009 07:29 AM
What IOS version are you running. The minimum IOS version for these modules is 12.4(15)T -
Jon
02-27-2009 07:35 AM
12.4(21a)
02-27-2009 07:52 AM
Jon
02-27-2009 08:03 AM
OK, thanks.
