10GE network using X2
Answered Question
Edison Ortiz Fri, 02/27/2009 - 08:15
My apologies, I was incorrect in my previous post.
The modules you've listed are the one to purchase for the X2-10GB connection.
The converter I mentioned is to provide 1GB connection via that same interface.
Leo Laohoo Fri, 02/27/2009 - 15:55
Yes you do. You need a pair: local and remote. Before you make the purchase, make sure the remote can support 10Gb modules: XENPAK or X2.
Correct Answer
Edison Ortiz Fri, 02/27/2009 - 16:39
Yes, you should be fine with that order.
viyuan700 Sat, 02/28/2009 - 17:31
See the following link it tells the distance you can reach over different kind od MM fiber.
check what kind of MMF(Multimode Fiber) you have and what is the distance between Core and access switch.
If youhave FDDI-grade, OM1 and OM2 fibers to meet the distance mentioned you need to order 2 mode conditioning patch cord.
Leo Laohoo Fri, 05/15/2009 - 18:37
Hi Vince,
You are correct, both sides should either be 10Gb OR 1Gb. You can't have 10Gb on one end and 1Gb at the other. It won't work.
