Creating command IP on switch
Answered Question
Feb 27th, 2009
I currently have to console into one of my switches that uses a private 172.x.x.x address and want to give it a command IP address in order to SSH into it. I'm not sure what the commands would be to do this....any help would be greatly appreciated!!
Correct Answer by Jon Marshall about 7 years 10 months ago
Kristy
To access a switch remotely you need a L3 vlan interface that is up/up with an IP address. Assuming vlan 1 interface on your switch
int vlan 1
ip address 192.168.5.10 255.255.255.0
ip default-gateway 192.168.5.1
where 192.168.5.1 is the L3 routed interface for vlan 1.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 02/27/2009 - 07:54
Kristy
int vlan 1
Jon
waldronks Fri, 02/27/2009 - 08:00
I know how to enable SSH or telnet, what I want to know is how to set up the command IP address on the switch so that I no longer have to console into the switch to get into it.
I believe Jon answered my question....thanks Jon!
