Policy Based Routing on ASR1006
Answered Question
Feb 27th, 2009
I have run PRB on multiple Cisco router 2800, 3800, 6500 etc. We use it for redircting to a WAN Accelerator. We setup the ASR the same as all our other with a route-map and an match criteria of an ACL and added the "ip policy route-map" statement to the LAN side interface, no traffic is hitting the ACL, upgraded to the latest software on the ASR 12.2(33)XNB2. I ahve also tried using WCCP with similar ACL's will not work either. Has anyone come across this issue?
Thanks Tom
Correct Answer by Laurent Aubert about 8 years 2 months ago
ACL counting when used for PBR is not supported on the ASR. But the PBR feature is working and supported starting XNB
Laurent.
Overall Rating: 5 (1 ratings)
Correct Answer
Laurent Aubert Fri, 02/27/2009 - 19:47
  • Cisco Employee,
Laurent.
