Registration rejected phone wireless 7921
Feb 27th, 2009
I am trying to connect a wireless phone 7921, I carry out the configuration in call manager 4.1 as such as i do with the other phones.
Through DHCP, the phone gets IP, i can make ping from the server of Call Manager.
The phone shows these messages:
Firmware update
Firmware update fail
Registration Rejected
What i can do?
Overall Rating: 5 (1 ratings)
Hythim Ali El Hadad Fri, 02/27/2009 - 16:40
Hi Pedro,
The most common reason for this registeration rejected is that you have run off all the pool of numbers that is used for auto registeration
So you can increase this pool
or delete unassigned numbers from the route plan report
wish this be helpful
testeven Fri, 02/27/2009 - 16:43
Hi!
What's the exact CCM version?
Are you using auto-registration or not?
It seems you are missing the latest Device Pack on your server. Please download it and install it.
You can get it from:
Voice and Unified Communications > Cisco Unified CallManager Version 4.1 > Unified Communications Manager/CallManager Device Packages
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875240
Hope this helps!
Teresa.
pesanchez2001 Fri, 02/27/2009 - 19:18
Hi teresa,
In this moment i don't have access to call manager, is 4.0 or 4.1, but when i add the phone in call manager i only see 7920 and i put it thinking that is 7920 series.
I think that the problem is to update the device pack, as you say.
This update is simple, has any inconvenient?
testeven Sun, 03/01/2009 - 18:58
Not that I know of. I have seen some cases in which the device pack fixes the issue.
HTH!
Tere.
pesanchez2002 Tue, 03/03/2009 - 05:10
Hi experts,
I have two servers 4.1(3)sr3c, working in cluster,I install the executable: cmterm-7921-sccp.1-3-2.exe, as said the link http://www.cisco.com/web/software/2820742 89/23577/cmterm-7921-sccp.1-3-2- Readme.html.
I Place the file in the directory tftp, and when i executed the software, appear the following files:
C:\Program Files\Cisco\TFTPPath
WLAN-1.3.2.SBN 1,320 kb
TNUXR-1.3.2.SBN 2,153 kb
TNUX-1.3.2.SBN 876 kb
SYS-1.3.2.SBN 2,035 kb
GUI-1.3.2.SBN 1,796 kb
CP7921G-1.3.2.LOADS 1 kb
APPS-1.3.2.SBN 2,602 kb
When i looking at Device Settings > Device Defaults, the firmware of phone 7921, does not appear in load Information.
I run the file in the main server, i have not done in the secondary server.
Is normal the size of the file CP7921G- 1.3.2.LOADS?
Do I have to install the software in the two servers, for that the phone 7921 appear in device defaults?
Should i restart the service cisco tftp server, in the tow servers, for that the phone 7921 appear in device defaults?
Should i restart the servers , for that the phone 7921 appear in device defaults?
rob.huffman Tue, 03/03/2009 - 06:47
Hi Pedro,
To add support for the 7921 in CCM 4.1(3) and have it available in the Device Defaults, you will need to install one of these Device Packs;
You can use Cisco Unified CallManager Device Package 4.1(65.0) or 4.1(78.0) with any 4.1(3) version above 4.1(3)sr1. This will add support for the 7906 as well as the 7921;
Here are the two ReadMe docs;
http://www.cisco.com/web/software/Voice/html/ciscocm.4-1-DevPack-65.readme.html#_Toc185233550
http://www.cisco.com/web/software/282074299/21541/ciscocm.4-1-DevPack-78_readme.html#_Toc185233550
Go to;
Tools & Resources
Downloads
Voice and Unified Communications > Cisco Unified CallManager Version 4.1 > Unified Communications Manager/CallManager Device Packages > 4.1(65) > ciscocm.4-1-DevPack-65.exe
Or;
Voice and Unified Communications > Cisco Unified CallManager Version 4.1 > Unified Communications Manager/CallManager Device Packages > 4.1(78) > ciscocm.4-1-DevPack-78.exe
Hope this helps!
Rob
