CME IP Phone Security
Feb 27th, 2009
I'm trying to set up SCCP via TLS in a CME (UC500)
I had read and follow the guidances in CME reference guide and administration guide.
Currently the phones stay in a Registering status but I can't figure out what is missing.
First of all, the phones (two 7911 just for lab tests) were in an endless loop trying to get IP address. I saw in debug the DHCP was assinging IP correctly but for some reason the phone is not able to get it. I set the two phones with fixed IP and the things going better, now the phones stay in registering status. Attached are two files:
a) debugging the registration process
b) running config
My tests had been done with ephones 11 and 12 only.
I would appreciate any help.
Thanks in advance.
Paolo Bevilacqua Fri, 02/27/2009 - 18:14
Can you try having a non-secure system first, then convert to secure after everything works for you ?
descalante2007 Mon, 03/02/2009 - 08:38
In non-secure way, everything works fine. My last status is this:
Phones have fixed IP address, they stop at registering process. I saw they have a CTL defined and security mode appears as authenticated.
So I think I'm very near to have my lab working but I don't know what is missing. I bet for signed files in CME, who knows?
Daniel Escalante.
