configuring DNS on firewall
Answered Question
Feb 27th, 2009
is it necessary to allow both UDP and TCP port 53 for accessing DNS servers through a firewall access-list?
Correct Answer by vikram_anumukonda about 8 years 1 month ago
tcp/53 is used for zone-transfers. if you are doing just normal queries udp/53 will suffice.
Overall Rating: 5 (1 ratings)
Correct Answer
vikram_anumukonda Fri, 02/27/2009 - 19:49
  • Bronze, 100 points or more
vikram_anumukonda Fri, 02/27/2009 - 20:03
Here is another reason why tcp/53 is used "A client can use TCP whenever it wants, and has to use TCP when the response it gets via UDP is truncated because it is too long"
duncanm Wed, 03/04/2009 - 08:49
tcp/53 is also used for large transfers.
