PPPoE & 800 Series router
Feb 27th, 2009
just got an 851 that I was hoping to deploy, but I've run into a snag. I can't seem to get pppoe connectivity setup either through the SDM or CLI - the command pppoe enable does not appear to be a valid command, it generates an error regardless of how it is called. The only command available seems to be pppoe-client
any ideas?
Overall Rating: 5 (2 ratings)
Edison Ortiz Sat, 02/28/2009 - 12:53
Thanks for the rating, Paolo :)
I fully agree, PPPoE is one of those technologies where we, Cisco, do not have much info on.
chavez243 Sat, 02/28/2009 - 18:08
This doc ended up helping the most:
but, still it's not written for the 851, so when it talks about FE 0, you have to substitute FE 4 - which is the WAN interface on the 851.
The doc also talks about an ATM interface which is missing on the 851 (perhaps unless you order it with the built-in DSL module).
I really can't get over how the SDM repeatedly sends utterly bogus commands to the router OS.
In the end I did get a pppoe connection working, mostly with the CLI, but then the SDM botched the firewall setup and i gave up for the time being... put the old router in place since I can't afford too much downtime.
I guess the next step is to dig up some docs on getting the firewall config'd
Paolo Bevilacqua Sun, 03/01/2009 - 03:13
Forget about the SDM. Is there only to put a checkmark on the datasheet. No professional ever uses it.
