Blocking address range on my router
sushil
I would like to block following address range on my router ext int.
71.64.0.0 - 71.79.255.255.
Will the mask be 0.15.255.255.
Should I follow access-list 101 deny ip 71.64.0.0 0.15.255.255 any.And add access group 101 to int.
Correct if I am wrong mask..
for below range.
116.120.0.0 - 116.127.255.255
It should go like this 0.7.255.255?
Reg,
Sushil
adamclarkuk_2
Level 4
Level 4
You are correct
71.64.0.0 - 71.79.255.255 = 0.15.255.255
116.120.0.0 - 116.127.255.255 = 0.7.255.255
Make sure you put this deny before any entries that may match any of the address's with a permit.
adamclarkuk_2
Level 4
Level 4
You are correct
