512MB Compact Flash in 2811/2851
Answered Question
Feb 28th, 2009
Dear All,
Can i use 512 MB Compact Flash in 2811 or 2851 router. Please advice.
Awaiting for reply.
Malik.
Correct Answer by Paolo Bevilacqua about 7 years 11 months ago
No, maximum is 256MB. If you insert a 512MB, results are not predictable.
Correct Answer by Nicholas Matthews about 7 years 11 months ago
Hi Malik,
From this FAQ:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
Default memory
Cisco 2800 uses external compact flash memory; Cisco 2801 uses non-error correction code (ECC) synchronous dynamic RAM (SDRAM), and Cisco 2811, 2821, and 2851 use Double Data Rate (DDR) ECC SDRAM
2801
Default and maximum:
• 64/128-MB compact flash memory
• 128/384-MB SDRAM
2811
• 64/256-MB compact flash memory
• 256/768-MB DDR SDRAM with ECC
2821
• 256-MB and 1-GB DDR SDRAM with ECC
2851
Looks like for above a 2801 the maximum is 256 MB.
hth,
nick
Overall Rating: 5 (2 ratings)
Correct Answer
Nicholas Matthews Sat, 02/28/2009 - 11:01
Hi Malik,
From this FAQ:
Default memory
2801
• 128/384-MB SDRAM
2811
2821
2851
hth,
nick
Correct Answer
Paolo Bevilacqua Sat, 02/28/2009 - 11:03
