SNMP OID for router temperature
Feb 28th, 2009
  • Red, 2250 points or more
I'd need more details how to get chassis temperature value from Cisco routers/switches.
So far I found 1.3.6.1.4.1.9.9.13.1.3.1.3 (ciscoEnvMonTemperatureStatusValue) present in CISCO-ENVMON-MIB shows the actual chassis temperature.
This works perfectly with 2800 routers, e.g.
But 2600s don't have this OID available, even while supporting CISCO-ENVMON-MIB according to CCO.
The only value available is 1.3.6.1.4.1.9.9.13.1.3.1.6 (ciscoEnvMonTemperatureState) but this doesn't show the teperature, only the normal/warning/critical status.
Does anybody know if some 2600 latest IOS provides the actual temperature value?
Milan
Overall Rating: 4 (1 ratings)
Joe Clarke Sat, 02/28/2009 - 12:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It's not a question of IOS support, but rather hardware support. The 2600s do not have the sensor hardware to provide the temperature value. Run a "show environment" on these routers. You should only see that the Board Temperature is, for example, "normal." you do not see a temperature value.
milan.kulik Sun, 03/01/2009 - 12:10
Hi Joe,
thanks a lot, this makes sense!
What about switches?
I realized 3560 is showing the temperature by sh env command, but the OID is not working :-(
(there is 1.3.6.1.4.1.9.9.13.1.3.1.3.1005 = 1 value only available).
Milan
Joe Clarke Sun, 03/01/2009 - 12:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Hmm, my 3560s do not show temperature degrees with "show env all":
FAN is OK
TEMPERATURE is OK
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1 Built-in Good
SW Status RPS Name RPS Serial# RPS Port#
1 Not Present <>
However, the CISCO-STACK-MIB's chassisTempAlarm does report correctly:
CISCO-STACK-MIB::chassisTempAlarm.0 = INTEGER: off(1)
