how does router connect to ATM switch?
Answered Question
Feb 28th, 2009
Hi every body!
In frame relay, router connects to frame relay switch using T1 line. The router may have integrated csu/dsu on T1 card or csu/dsu can be stand alone unit .
1)In ATM network, does router have the intergrated cs/dsu on ATM interface card on router?
2) Does router connect to ATM switch using T1 line?
thanks a lot!
Correct Answer by Edison Ortiz about 7 years 8 months ago
1) Yes, here is one example - this is for T3 (similar can be found for T1):
2) It's called ATM Circuit and it can be a T1/E1 or T3/E3.
Overall Rating: 5 (1 ratings)
