Cisco VPN Client, Verizon FIOS and Remote Desktop
Feb 28th, 2009
I am using the Cisco VPN client to connect to an ASA5520. I am having a problem establishing a remote desktop session over Verizon FIOS using a Westell 9100 EM router. ICMP does not work either.
Everything works fine if I attach over a Brighthouse broadband connection.
Has anyone seen this type of behavior?
Farrukh Haroon Mon, 03/02/2009 - 00:21
  • Red, 2250 points or more
Have you tried using IPSEC over UDP instead of IPSEC?
Farrukh
t.radan Mon, 03/02/2009 - 06:22
Farrukh,
I appreciate your response, but can you please clarify. Do you mean IPSec over TCP instead of UDP?
Teresa
Farrukh Haroon Mon, 03/02/2009 - 21:42
You can try any. I prefer to try IPSec over UDP first due to less overhead.
Farrukh
