unity - unified messaging
Feb 28th, 2009
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
hi guys
if we have unity with unified messaging and we want to stop unity from sending voicemail .wav files to users outlook how can this be done ?
thank you
Hythim Ali El Hadad Sun, 03/01/2009 - 02:24
  • Silver, 250 points or more
Hi Marwan,
It has been addressed before by Ginger
You can do the following:
If you would prefer to have a "voicemail-only" implementation that uses Exchange as the backend store, here are some steps you can take:
1. Create a new COS that disables in the features section text to speech and faxmail. You may want to create a separate voicemail only user template for importing the user as well.
2. Create a new user account, we use vm-xxxxx for the user's phone extension
3. Import the user into Unity
4. Then hide the user from the GAL. Or this can also be accomplished in the user template.
Wish this be helpful
Marwan ALshawi Sun, 03/01/2009 - 04:23
hi thanks for this answer
if i am using the default template for COS
and i disable the text- to speach and faxmail will dose the job for me ?
what about the creating user sorry but i didnt get !!!
Jonathan Schulenberg Sun, 03/01/2009 - 09:07
  • Cisco Designated VIP,
    2017 IP Telephony
If you are using Unity Unified Messaging, Unity uses the Active Directory user's Exchange mailbox as it's message store. That's the whole point of Unified Messaging. If you do not want Unified Messaging and do not want to migrate to another product (such as Unity Connections), then your next-best bet is to create separate Active Directory users and Exchange mailboxes. Because it's a different user and mailbox, the real user won't see the messages in their inbox.
Marwan ALshawi Sun, 03/01/2009 - 13:04
hi
thanks for this
what about the above post
what did they mean in hide the users from GAL or can be done in the user template !!
Ginger Dillon Wed, 03/11/2009 - 11:48
  • Blue, 1500 points or more
Hi -
What this means is (there are two options to hide the user so that users won't send email messages):
1. Hide the user from the Global Address List (used by Outlook to send email messages in the organization) by editing the user account and check the box - Exchange Advanced tab. Or ...
2. On the Unity subscriber template used for creating/importing the user, UNcheck the box on the Profile page tht says "Show subscriber in e-mail server address book". As the user is created/imported, it will get hidden from the GAL.
Ginger
