2960 console port problem
Feb 28th, 2009
Hi dear all,
I have a problem with catalyst 2960-24TT-L. When I connected the console port to PC and using hyperterminal, there is no response, even i changed the baud rate and other parameter in hyperterminal.
Could you have suggestion ?
Rgds,
wan
gmcdowell Sun, 03/01/2009 - 10:46
Are you using the standard Cisco blue cable, or are you using one of those beige (off-white) DB9-RJ45 converters? If the latter, that can be the problem - they are not all pinned the same! The wrong one will give you a blank-screen, no response. In contrast, the wrong baud will often give you funny-character, unintelligible gibberish.
Also, make sure hyperterminal is configured to connect to com1 and that com 1 is set for 9600,8,none,1,none.
p.s. Check out Tera Term Pro - free console/telnet/ssh sw w/ (imho) a much nicer interface than hyperterm.
