huge log files in cw LMS
Answered Question
Feb 28th, 2009
  • Silver, 250 points or more
hello
Today in ciscoworks LMS, I found that c:\ drive is almost full.
I found 2 huge files :
-c:\program files\ CSCOpx\log\ConfigMgmtServer.log 2 Giga
- c:\program files\ CSCOpx\MDC\tomcat\logs\stdout.log 6 Giga
Can we limit the size of these 2 log files so that the C drive will not be full in the future?
Correct Answer by Joe Clarke about 8 years 3 weeks ago
Yes. You can configure logrot.pl to rotate these logs periodically when they reach a certain size. Search the Common Services online help for "logrot" for more information on how to configure this.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sun, 03/01/2009 - 00:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ohassairi Sun, 03/01/2009 - 21:54
thanks jclarke for the infos
here is the procedure:
C:\Program Files\CSCOpx\bin>perl.exe logrot.pl -c
Read config successfully.
Logrot Configuration Menu
1. Edit variables
2. Edit log files
3. Quit and save changes
4. Quit without saving changes
Enter option: 1
Number Variable Name [Variable Value]
1. Backup Directory []
2. Restart Delay [60]
q. Go back
Enter variable number to change: q
1. Edit variables
2. Edit log files
Enter option: 2
Warning: No logfiles found.
a. Add logfile(s)
d. Delete logfile(s)
q. Go back
Enter option or logfile number to edit: a
Enter logfile path []: c:\program files\ CSCOpx\log\ConfigMgmtServer.log
Enter number of archives to keep [0]: 3
Enter maximum file size (in kilobytes) [1024]: 5120
Compression extension (gz,Z,bz2): gz
Number Logfile Name Number of Archives Max Size Compress
1. "c:\program files\ CSCOpx\log\ConfigMgmtServer.log " 3 5120 gz
a. Add logfile(s)
q. Go back
Enter logfile path []: c:\program files\ CSCOpx\MDC\tomcat\logs\stdout.log
2. "c:\program files\ CSCOpx\MDC\tomcat\logs\stdout.log " 3 5120 gz
a. Add logfile(s)
q. Go back
Enter option or logfile number to edit: q
1. Edit variables
2. Edit log files
Enter option: 3
