IP phone 7980
Mar 1st, 2009
Hii experts,,
I have an issue with my phone 7980 when I try to make a call throught the PRI it is only ring once then busy tone.
My VGW is 2811 and the PRI configuration as below:
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
voice-port 0/0/0:15
bearer-cap Speech
And I configure a voice calss codec with G711 and g729 codecs and applied it to the Voip dial peer.
PLZ note that the calls therougt VGW 3825 are working fine.
Thanks..
Anonymous (not verified) Fri, 03/06/2009 - 05:42
What type of protocol is being used in the CCM setup for the gateway? MGCP or H323?
amarmn1975 Tue, 03/10/2009 - 21:24
Hii,,
Thanks for all .. I found a solution for thais problem, it just was a codec problem. I it is ok now..
Thankks..
