copy ios from laptop to catos 6509 switch
Mar 1st, 2009
hi there,
I havea IOS file on my laptop and its consoled into a 6509 catos switch.
Do you know how to move the file to the flash card of the switch via tftp on laptop?
Thank you,
Giuseppe Larosa Sun, 03/01/2009 - 09:10
Hello Sirajul,
to be able to use TFTP you need a LAN connection between your laptop and the C6509.
let's suppose you have on C6509:
int vlan 1
ip address 10.0.0.1 255.255.255.0
no shut
a 48 ports FE/GE linecard
int fas3/1
switchport
switchport mode access
swithport access vlan 1
you connect with a straight RJ-45 UTP cable to the LAN NIC of laptop
you give to the laptop an ip address in subnet 10.0.0.0/24 for example
10.0.0.253 255.255.255.0
you then need a TFTP server software on the PC and to execute it
from the console you can give
copy tftp flash (*)
(*) you can use dir /all to find the names of the filesystems in your C6500.
the actual name can be slot0: for example
then you are asked for
ip address
filename
give the pc ip address, the filename as it is on the PC hard disk
Hope to help
Giuseppe
sirajmuneer Sun, 03/01/2009 - 09:22
Thanks. But how if the c6509 is running on CatOS?
What are the commands in CatOS?
glen.grant Sun, 03/01/2009 - 12:42
In catos its pretty much the same. Depend s on what media you have in your 6509.
copy tftp bootflash:
copy tftp slot0:
copy tftp disk0:
