PIX 515 inside interface resetting
Mar 1st, 2009
Hello, I woke up this morning to a bunch of alerts that my 515 is unreachable, then the alerts cleared off a minute or two later.
I took a look at the 515 and there are no errors, but the inside interface shows a bunch of interface resets - just wondering what might cause that? Bandwidth is light.
Could tcp/udp timeouts stack up and cause the interface to reset?
We have a ACS server that the PIX should be logging to, I havent had a chance to get at the logs to see any further yet, just wanted to see if someone has a quick answer, thanks!
