DMVPN
Answered Question
Mar 1st, 2009
I am trying to configure DMVPN but my tunnel ip can't ping each other. I have connected two routers more like a hub and spoke network ut I only have one conneted at this stage for testing purposes.
Please check why my router's cant ping my device, below are my configs:
1st problem
I cant configure the tunnel destination on the hub.
HUB
DUT(config-if)#tunnel destination 172.16.0.1
The tunnel destination can not be configured under the existing mode
crypto isakmp policy 10
encr aes 256
hash md5
authentication pre-share
crypto isakmp key 6 cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set dirkstrong esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES256-SHA esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile DMVPN
set transform-set ESP-AES256-SHA
crypto ipsec profile strongdirk
set security-association lifetime seconds 120
set transform-set dirkstrong
crypto ipsec profile test
interface Tunnel0
bandwidth 1000
ip address 172.16.0.2 255.255.0.0
no ip redirects
ip mtu 1400
ip nhrp authentication cisco
ip nhrp map multicast dynamic
ip nhrp map 172.16.0.4 10.0.44.1
ip nhrp network-id 1000
ip nhrp holdtime 360
ip nhrp nhs 172.16.0.4
ip tcp adjust-mss 1360
tunnel source 1.1.1.1
tunnel mode gre multipoint
tunnel key 12345
tunnel protection ipsec profile DMVPN
Spoke
encr aes 256
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
mode transport
interface Tunnel0
bandwidth 1000
ip address 172.16.0.4 255.255.0.0
no ip redirects
ip mtu 1400
tunnel source Loopback0
tunnel key 12345
tunnel protection ipsec profile DMVPN shared
Correct Answer by Leo Laohoo about 8 years 3 weeks ago
Dynamic Multipoint VPN (DMVPN) feature allows users to better scale large and small IPSec VPNs by combining generic routing encapsulation (GRE) tunnels, IPSec encryption, and Next Hop Resolution Protocol (NHRP) to provide users with easy configuration through crypto profiles, which override the requirement for defining static crypto maps, and dynamic discovery of tunnel endpoints.
Configuring Dynamic Multipoint VPN (DMVPN) using GRE over IPSec between Multiple Routers
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008014bcd7.shtml
Overall Rating: 5 (1 ratings)
Leo Laohoo Sun, 03/01/2009 - 16:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What is your IOS version and feature set?
Correct Answer
Leo Laohoo Sun, 03/01/2009 - 20:41
  • Hall of Fame,
    2017 LAN, Wireless
Giuseppe Larosa Mon, 03/02/2009 - 03:21
  • Hall of Fame,
    Founding Member
Hello Lawrence,
the tunnel destination command applies only to normal point-to-point GRE tunnels, here you are using point-to-multipoint GRE tunnel mGRE.
second note:
the hub should be also the NHRP server, your HUB configuration points to the spoke unless what you call spoke is your hub.
Hope to help
Giuseppe
jazou Sun, 06/26/2011 - 16:56
For DMVPN, there is no need of configuring tunnel destination on hub site.  That's because hub is using mGRE tunnel, which is a multipoint tunnel.
Hub must be mGRE tunnel, and Spokes can be mGRE or GRE tunnel.
And also remember, your hub site should be configured as NHRP server, the NHRP configuration should be (for example):
HUB:
interface tunnel 0
ip nhrp authentication ***
ip nhrp network-id 100000
SPOKE:
interface tunnel 0
ip nhrp map [hub tunnel ip] [hub phsical ip]
ip nhrp nhs [hub tunnel ip]
For more information,  you can go:
www.cisco.com/go/dmvpn
or you could refer to the configuration guide above.
josem_155 Thu, 09/19/2013 - 08:35
Hi ,
I have a customer who wants to deploy a Metro-E among all sites. But, when I see what he wants i saw he wants to deploy DMVPN over that MEtro-E as well. My question is: is this ok? I mean, Metro-E is not secured already? What should he deploy DMVPN ob that metro connection for?
I have read a lot of papers and I saw that DMVPN is good to be deploy to secure connections over internet, as backup or over a MPLS VPN ( aslgo GETVPN) so im confused with this.
Joseph W. Doherty Thu, 09/19/2013 - 11:07
Suggest you post as an independent question.
johnlloyd_13 Thu, 09/19/2013 - 18:38
  • Blue, 1500 points or more
hi,
i've replied to your other post. kindly avoid duplicate post or create your own thread next time
