Mark Yeates Sun, 03/01/2009 - 19:05
The last response in definitely not the answer! I suggest taking a look at the 4 exams and decide which you are most comfortable taking first. Take the exams that you are more knowledgeable first, and as you progress take them when you feel comfortable taking them. I don't believe there is a best way in taking them in any particular order.
HTH,
Mark
