DCHP from one VLAN to another using one DHCP Svr?
Answered Question
Mar 1st, 2009
I'm working in a home lab with a 2950 switch and a 2611 router. The switch is configured with two VLANs (10 and 20). There is one host connected to a port on VLAN 10 (F0/3). VLAN 20 contains two hosts (F0/5 and F0/7). Switch port F0/15 is connected to the router's e0/0 interface. F0/15 is setup as a trunk port. The router is running IOS c2600-d-mz.121-27b (supports 802.1q).
The host on switch port F0/5 is on the same subnet as F0/7. F0/7 is running a DHCP server. F0/5 gets it IP from the DHCP server. The host on F0/3 VLAN 10 does not have an IP address. I would like this host to receive a different subnet IP address using the DHCP server.
I have two scopes setup on the dhcp server. One for the 192.168.10.0 network and one for 172.16.10.0. Sub interfaces are setup on the e0/0 of the router. Each sub interface is configured with dot1q encapsulation and an IP address for the different subnet. I want the host on switch port F0/3 to recieve and IP address from the 172.16.10 scope.
Note: When I configure the host on F0/3 with an IP address on the 172.16.10.0 network I can ping the other hosts on the 192 network. So, the trunk is working properly. What am I missing?
[Here is snapshot of the running config of the router.]
interface Ethernet0/0
no ip address
interface Ethernet0/0.1
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
ip helper-address 192.168.10.1
interface Ethernet0/0.2
encapsulation dot1Q 200
ip address 172.16.10.254 255.255.255.0
[Here is a snapshot of the switch]
interface FastEthernet0/3
switchport access vlan 20
no ip address
duplex full
speed 100
interface FastEthernet0/5
switchport access vlan 10
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/15
switchport mode trunk
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
ip default-gateway 192.168.10.254
Correct Answer by Richard Burts about 8 years 4 months ago
HM
I am glad that it is solved. Yes it is frequently the simplest mistakes that cause the perplexing issues.
If the issue is solved the perhaps you can use the ratint system to indicate that the issue is solved? This would allow other readers in the forum to take advantage of the discussion here.
Rick
Overall Rating: 5 (1 ratings)
glen.grant Sun, 03/01/2009 - 20:05
  • Purple, 4500 points or more
Turn on portfast on your switchports that pc's will be attached to . Also verify on the switch that the layer 2 vlan was created on the switch with the show vlan command . Also on your subinterface you have "dot1q encapsulation 200" instead of 20 .
hackermuscle Mon, 03/02/2009 - 18:18
Vlan 20 was a typo.
Still no joy with enabling portfast on the host interfaces. Here's the running config from the switch.
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
switchport access vlan 200
speed 100
duplex full
spanning-tree portfast
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 192.168.10.30 255.255.255.0
no ip route-cache
interface Vlan200
no ip address
no ip route-cache
shutdown
Thx
Richard Burts Mon, 03/02/2009 - 20:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
HM (or whoever you are)
Is the device that is running as the DHCP server really on address 192.168.10.1? And if so does it really have an appropriate scope defined for 172.16.10.0?
My guesses are either that the server address does not match the helper address or that its scope is not correctly configured (including the correct default gateway address).
Rick
hackermuscle Tue, 03/03/2009 - 07:12
Yes. The DHCP server's TCP/IP address is 192.168.10.1. The hosts on VLAN 10 receive IP addresses dynamically from this server without any problem.
I verified the scope this morning. It is a Windows 2003 Server DHCP configuration. Basically, a wizard does all the work for me. :)
Just a reminder. When I configure the host on VLAN 200 with a static IP address 172.16.10.10 for example, I can ping the hosts on the 192 network as well as the 172.16 sub interface on the router. So, the trunk works.
I don't see any DHCP broadcasts while running Wireshark on the 192.168.10.1 interface when trying to renew address of the host on VLAN 200. The packets don't appear to be making it out of e0/0 on the router.
Is the IP helper-address configuration on the correct interface? e0/0 is not assigned an IP. e0/0.1 is on the 192 net and e0/0.2 is on the 172 network.
Richard Burts Tue, 03/03/2009 - 14:15
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
HM
If the DHCP server address is really 192.168.10.1 then the helper-address is configured correctly.
As for running Wireshark on the 192.168.10.1 interface, you will not see any broadcasts from VLAN 200. What the helper-address configuration does is to receive the broadcast request received by the interface and build a unicast message to the helper address and forward it. So the server will receive these requests from VLAN 200 as unicast and not as broadcast.
Is the scope for 172.16.10.0 set up as a separate scope or is it part of a superscope?
Also I notice in the config that you originally posted that you have configured a helper-address under interface Ethernet0/0.1. Since this is the VLAN/subnet where the DHCP server is located you do not need the helper-address configured on that interface. You only need the helper-address on interfaces which will receive the DHCP broadcast request and need to forward to a remote subnet where the DHCP server is located.
Rick
hackermuscle Tue, 03/03/2009 - 14:44
Hi Rick,
Understood about the unicast packets. In any case, I don't see any traffic on the DHCP server's interface when updating the host on VLAN 200.
I'm definitely not using a superscope. I know that is where a lot of folks get into trouble.
Yes, I do have the ip helper-address configured on e0/0.1 and e0/0.2 sub interfaces. I will remove the statement from e0/0.1. Do you think this is the cause of the problem?
Richard Burts Tue, 03/03/2009 - 15:03
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
HM
While I would suggest that you remove the helper-address from the e0/0.1 since it is not needed, I do not believe that having it there causes any problem.
Is it possible that the router is configured with no service dhcp?
Rick
hackermuscle Tue, 03/03/2009 - 16:25
Solved. OMG! It's always the simplest mistakes that cause the biggest issues.
DHCP Scope was 172.16.0.0
e0/0.2 was 172.16.10.0
Duh..
My host received an IP address from the DHCP server on the other VLAN. Yippee.
Thanks for everyone's help on this.
Correct Answer
Richard Burts Tue, 03/03/2009 - 20:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
HM
Rick
hackermuscle Mon, 03/02/2009 - 18:35
Switch#show vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/4, Fa0/8 Fa0/9, Fa0/10, Fa0/11, Fa0/12 Fa0/13, Fa0/14, Fa0/16, Fa0/17 Fa0/18, Fa0/19, Fa0/20, Fa0/21 Fa0/22, Fa0/23, Fa0/24, Gi0/1 Gi0/2
10 VLAN0010 active Fa0/5, Fa0/6, Fa0/7
200 VLAN0200 active Fa0/3
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
