host not found
Answered Question
Mar 1st, 2009
I'm using UCM 6.1. Whenever i press the directory button on the ip phone, it will display host not found.
What could be the cause of it?
Correct Answer by binu.john about 7 years 12 months ago
In CM Administration-Go to Enterprise Parameters,change the URL paths with IP Address of Publisher instead of Hostname.Restart your Ip Phone and see.
Overall Rating: 3 (1 ratings)
Correct Answer
binu.john Sun, 03/01/2009 - 20:14
robbie.teo Sun, 03/01/2009 - 21:35
thanks. that solved my problem. 1 more basic setup i like to ask you.
Currently my ip phone top right hand side shows the DN number instead of name
I tried many ways but can't able to change it. you have any clues? Thanks
Nicolas Mansour Mon, 03/02/2009 - 12:44
Unfortunately you can't change that in CCM that's possible only in CM Express :)
binu.john Tue, 03/03/2009 - 22:51
You are welcome:
Try from CM Administration,Device-Phone and from the Line settings add the name in the Line Display field.
Have a nice day.
