dario.didio Mon, 03/02/2009 - 02:12
  • Silver, 250 points or more
What I would do:
Is it a kind of copy/paste migration?
Is it layer2/layer3 design?
- list all IP addresses for the ACE (physical for the vlan interfaces + aliases (VRRP like address))
- list all VIP addresses + services (fe. http, dns, ftp...)
- list all real servers that will be used, ordened per VIP (serverfarm)
- list all probes per real server
- list all specific exceptions (fe. stickiness, cookie insertion, NAT...)
- list all network parameters (fe. static routes, default routes, ACLs for management...)
I think this should help you already. The rest depends on the design and complexity that is in your setup.
Hope this helps.
Dario
axfalk Mon, 06/15/2009 - 17:57
I am curious if you have run into the predictive load balancing method on F5 that does not exist in the ACE. What did you end up using instead?
Thanks..
