Giuseppe Larosa Mon, 03/02/2009 - 02:48
Hello Sudhir,
channelized interfaces require to configure a hierarchy:
first the underlying STM-1 controller has to be initialized then you need to configure the tributary controllers until you reach the E1 level.
see
http://www.cisco.com/en/US/docs/ios/12_4/interface/configuration/guide/h_stm5.html
this is for a PA in a flexwan, but the config should be similar for the SPA in the SIP.
this is the right link
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76cfstm1.html
Hope to help
Giuseppe
Giuseppe Larosa Mon, 03/02/2009 - 03:25
Hello Jon,
thanks so the threshold is at 4500 points
don't worry I will stay here at purple level for a while :-)
Best Regards
Giuseppe
Jon Marshall Mon, 03/02/2009 - 03:32
"thanks so the threshold is at 4500 points"
Yes not quite sure why it says 3750 as it has always been 4500.
"don't worry I will stay here at purple level for a while :-)"
No worries, it does seem to take forever to get out of purple tho :-)
Jon
sudhir.bhagat Mon, 03/02/2009 - 04:04
Thanks a lot.!!!
But please clear this line as i am bit confused "first the underlying STM-1 controller has to be initialized then you need to configure the tributary controllers until you reach the E1 level".
Specially for tributary Controllers.
regards
Giuseppe Larosa Mon, 03/02/2009 - 04:56
Hello Sudhir,
in simpler words:
you need to configure a controller that represents the whole STM-l link.
Then following the documentation you need to define some Virtual Containers (payload objects) until you can define a controller E1.
To be able to define an E1 you need first to define a VC that carries inside a T3 DS3 rate and then an E1
refer to the second link in my first post
Hope to help
Giuseppe
