Remote loging
Mar 2nd, 2009
We are having own intranet system at our organization with LAN IP 192.168.0.0/24.We are having an internet leased line with cisco 1841 and ASA 5510.I want to know that is it possible to connect the intranet or our local network from outside through internet.If yes how???Please discuss...
drolemc Fri, 03/06/2009 - 05:55
Yes you can do this setup through VPN. Basically, a VPN is a private network that uses a public network (usually the Internet) to connect remote sites or users together. Instead of using a dedicated, real-world connection such as leased line, a VPN uses "virtual" connections routed through the internet from the company's private network to the remote site or employee.
soumik1979 Fri, 03/06/2009 - 05:58
Ya.But how this can be done.Do you have any documents regarding that..
Paolo Bevilacqua Fri, 03/06/2009 - 12:37
Hi, I would recommend you hire a qualified techncian for this, as even if an apparently simple task, can become very frustrating for a non cisco certified person.
