TACACS config on Cisco Pix & ASA
Anand Narayana
Level 6
Level 6
I am looking for a similar configuration for my Cisco PIX & ASA to configure with Cisco ACS, with the below said commands I could able track what command a user has entered on the switches/router. Any help is highly appreciated for me to configure in PIX & ASA.
aaa new-model
aaa authentication login default group tacacs+ enable local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
5 Replies 5
Thanks for the response. But this also does accounting like the command whats ever I enter will be listed in the "Report Activity" in the Cisco ACS?
The commands that you enter will be shown on either Tacacs Administration or Command accounting, it depends on what version of ACS you have. As the lines needed for command accounting you need to enter pretty much this:
Note command accounting only works with TACACS.
aneelaka
aaa-server protocol test
aaa-server host .. key...
and all commands should be same
Let me give a try on Monday :-)
