Reloading a 4507/4510RE switch with dual sup
Mar 2nd, 2009
Dear Friends,
While reloading a switch with multiple sups, the reload command reloads just the active supervisor. Right?
Is there any command to reload both the sups together? I am talking about 4507/4510RE switches with IOS 12.2(50)SG.
Or the only solution is to type reload twice, once for the active sup and once for the standby sup because it became active?
Thanks a lot
Gautam
Mark Yeates Mon, 03/02/2009 - 03:38
Gautam,
The reload command will reboot the entire switch. It does include both supervisors.
HTH,
Mark
agugger Wed, 03/04/2009 - 14:14
Hi Gautam
Check ones the command below:
redundancy reload {peer | shelf}
see also other commans like:
redundancy force-switchover
