Cisco ADSL WIC
Answered Question
Mar 2nd, 2009
Dear All,
I have installed a Cisco ADSL WIC in my Cisco 1841 Router.
I Have the following data from my ISP:
- Username : user
- Password : pass
- Protocol : PPoE LLC
- VPI : 50
- VCI : 0
How Can I Configure My Router to replace the ADSL Modem I recieved from my ISP using the above configuration?
Thanks alot
Correct Answer by DialerString_2 about 7 years 10 months ago
The only difference is I'm running PPPOE and you're running PPPOA and I'm not natting the f0/0 interface. I also have a static ip address from the provider.
Plugged the adsl wic directly into the dsl wall jack. My line doesn't use a dsl filter so if you have one you may want to try it with and with out it.
I would set this up for pppoe, just my 2 cents. Oh, the config I posted works like a charm.
sh int dsl atm0/1/0 (look for "showtime" next to modem status) this mean that you're trained with the provider.
sh atm pvc (shows the status of the pvc which should be up)
Overall Rating: 5 (1 ratings)
DialerString_2 Mon, 03/02/2009 - 09:50
Let me know if you need a config for this. I have one setup using only the ADSL wic in a 1841 router. I also have the VPN setup also.
mmajai_cisco Tue, 03/03/2009 - 04:05
Yes,
Actually I set my router with following config.
BusinessOne#sh run
Building configuration...
Current configuration : 1590 bytes
version 12.4
service password-encryption
hostname BusinessOne
boot-start-marker
boot-end-marker
enable secret 5 $1$0cys$d5c9ungrrlTMwiV11JoMO.
enable password 7 141614030F557878
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface FastEthernet0/0
ip address 172.19.134.7 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clockrate 2000000
interface ATM0/1/0
no ip address
ip mtu 1452
ip tcp adjust-mss 1300
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
ip mtu 1452
pvc 0/50
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1452
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname afhc
ppp chap password 7 000F1A51025F59555B
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 172.19.134.0 0.0.0.255
control-plane
line con 0
password 7 0207025308545F711A
login
line aux 0
line vty 0 4
login
end
All what I need is to replace my ADSL modem I have from my ISP with this 1841 Router-with-adsl-wic
I do not think that I need VPN
Thanks So Much for both of you
Correct Answer
DialerString_2 Tue, 03/03/2009 - 06:26
mmajai_cisco Tue, 03/03/2009 - 20:31
Dear DialerString,
I'm also like to use the PPPoE LLC as you can see in my initial configuration I posted in the top of this page, and I can get only Dynamic IP from my ISP, also, I plugged my ASL WIC directly to the ADSL Wall Jack,
As a newbie in the issue, I do not know how to remove the filter setting from the posted configuration above.
I have positive output from both "sh int dsl atm" and "sh atm pvc" and from debugging also.
The only problem I have now is that I do not know how to configure the inteface to get real IP from my ISP !!!
Below is the output I get from "sh ip int brief"
BusinessOne#sh ip int brief
FastEthernet0/0 172.19.134.7 YES NVRAM up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
Serial0/0/0 unassigned YES NVRAM administratively down down
ATM0/1/0 unassigned YES NVRAM up up
ATM0/1/0.1 unassigned YES unset up up
NVI0 unassigned YES unset up up
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset down down
Dialer0 unassigned YES manual up up
- by thw way, whay NVRAM means in this .
Thanx alot
DialerString_2 Tue, 03/03/2009 - 20:48
Configure your atm to use a dialer pool because you should see a ip address in your sh ip int brief for di0.
ATM0/1/0.1
pvc 0/50
pppoe-client dial-pool-number 1
Dialer0
dialer pool 1
