Router to Router Ipsec (RSA Key) cisco 1841
Mar 2nd, 2009
Connecting between two routers for Ipsec VPN.
How to generate the RSA Key for session. The configuration is as follows.
ROUTER A
crypto key pubkey-chain rsa
named-key [email protected]
key-string
quit
username manju password 0 cisco
crypto isakmp policy 1
authentication rsa-encr
crypto isakmp identity hostname
crypto isakmp keepalive 20 5
crypto ipsec transform-set airtel esp-des esp-sha-hmac
mode transport
crypto map airtel 10 ipsec-isakmp
set peer 10.97.37.1
set transform-set airtel
match address 101
interface Tunnel0
ip address 10.10.10.2 255.255.255.0
ip mtu 1420
tunnel source FastEthernet0/0
tunnel destination 10.97.37.1
crypto map airtel
interface FastEthernet0/0
description $ETH-LAN$
ip address 172.26.8.1 255.255.255.0
duplex auto
speed auto
no cdp enable
crypto map airtel
interface Serial0/1/0
ip address 192.168.10.2 255.255.255.0
ip virtual-reassembly
clock rate 2000000
router eigrp 10
redistribute static
network 10.0.0.0
network 172.26.0.0
network 192.168.10.0
no auto-summary
ROUTER B
key-string
quit
mode transport
set peer 172.26.8.1
match address 101
interface Tunnel0
ip address 10.10.10.1 255.255.255.0
ip mtu 1420
tunnel source FastEthernet0/1
tunnel destination 172.26.8.1
crypto map airtel
interface FastEthernet0/1
ip address 10.97.37.1 255.255.255.0
duplex auto
speed auto
crypto map airtel
router eigrp 10
network 10.10.10.0 0.0.0.255
network 10.97.37.0 0.0.0.255
no auto-summary
ip default-gateway 10.97.37.254
ip route 10.10.10.0 255.255.255.0 10.97.37.252
ip route 172.26.8.0 255.255.255.0 10.97.37.252
ip route 192.168.10.0 255.255.255.0 10.97.37.252
adamclarkuk_2 Mon, 03/02/2009 - 05:27
You need to generate an RSA key pair for this using the command :-
crypto key generate rsa usage-keys label modulus
You will need to set a domain name on the device first using the command :-
ip domain name
These keys can then be used for signing and encryption
To view the keys, use :-
sh crypto key mypubkey rsa
ntmanjunath Mon, 03/02/2009 - 21:53
I set the domain name (netsol.com) and I generated the RSA Key in both the routers.What is the next command for establishing the session between two routers.
view the keys:-
AIRTEL-DELHI#sh crypto key mypubkey rsa
% Key pair was generated at: 23:15:07 Chennai Mar 2 2009
Key name: netsol.com
Storage Device: not specified
Usage: Signature Key
Key is not exportable.
Key Data:
3054300D 06092A86 4886F70D 01010105 00034300 30400239 03A4ABC5 402E4D46
7DB113D1 B11656BC 71E17BBC 2EA53D73 4EE7CA01 6A10A2F8 82EDA544 CE74EB6C
2D44EB37 57F51F25 0A68BB34 267765D0 C7020301 0001
% Key pair was generated at: 23:15:08 Chennai Mar 2 2009
Usage: Encryption Key
Key Data:
3054300D 06092A86 4886F70D 01010105 00034300 30400239 02D8598E CAF6C7DF
A80BEE6C 52AED8B6 9994E464 15B41D58 EE7252A3 7F7588EA 27D6A516 E013A1BA
11E8DF19 91268B04 1088C357 41584863 8B020301 0001
Key name: netsol.com.server
Temporary key
Key Data:
307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00E6826B 79E43452
B8DCEA79 9BE0A951 70FA4512 BC9138CB F10196A5 22E823D0 29D7FE80 78C620A1
32782865 8B07AAB2 8DD13E44 EA3197BA 72F8A559 7AC187E2 1D25950B E4AE3E72
9B2077D3 5CC9B19D D5514832 23CB8B09 B9C1C68E 1F916437 F9020301 0001
