ACS 4.1.1.23.5 REPLICATION PROBLEMS
Mar 2nd, 2009
I upgraded two ACS SE to version 4.1.1.23.5 to solve this problem TACACS+ Command Accounting does not work.
they were working ok, but the replication between them started to fail.
these are the messages that i receive
ACS Primary: ACS 'backup' has denied replication request.
ACS Backup: Inbound database replication from ACS 'Primary' denied
please help i deeply appreciate..
Overall Rating: 5 (2 ratings)
ochalmers Tue, 03/03/2009 - 09:56
No, I checked the AAA Server's IP Addresses on the two servers and they've got the real ip addresses.
Any other idea??
Ivan Martinon Tue, 03/03/2009 - 10:44
Can you check that the secondary server does not have any replication mates? make sure nothing shows up in there, also double check the ip addresses and keys, make sure they are not under any NDG (network device group) and if they are make sure the shared key is the same.
ochalmers Wed, 03/04/2009 - 10:07
I took off the replication partner on the secondary ACS server and the replication service works again. thanks a lot.
sahmedshahcsd Wed, 03/04/2009 - 03:11
Make sure you initiate the replication process on primary ACS server in order for the secondary ACS should get replicated.
Hope this helps
sshareef Fri, 03/06/2009 - 13:38
Thanks for sharing this tip. I was initiating on secondary. so the bottom line is replication in ACS is is a push operation and not pull.
