CCIE at San Jose
Mar 2nd, 2009
I'd like to know if there is any receptionist at San Jose Lab center working on Sunday as my exam will be on Monday and I'd like to visit the lab center on Sunday to check the building location and the lab location.
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 03/02/2009 - 07:10
Hi Youssef,
You can try giving them a call to find out directly;
150 West Tasman Drive
San Jose, CA 91354
Phone: 408-526-8001
Hope this helps!
Rob
jim_berlow Mon, 03/02/2009 - 09:37
I doubt that there is a receptionist on duty Sunday. Even if there is, there are no labs going on and I doubt they will let you view the lab without a proctor on premises.
Probably the best you can do on Sunday is to find the building, where to park and figure out how much time you need to get there (keep in mind that traffic is 3x worse on Monday morning than what you will see Sunday).
Good luck,
Jim
gogasca Sat, 03/14/2009 - 23:35
Sorry...No man, i work in front of building C and used to go on sundays there for my ccie studies and no one there.
youssef.shaaban Sun, 03/15/2009 - 04:59
so I just can know the building location & the parking but not the lab location in building as i cant enter the building!
Is that right?
ccannon88567 Mon, 03/16/2009 - 08:40
Don't panic buddy - that's how it will all start to go down hill. Just give yourself plenty of time to arrive and check it out before hand.
izackvail Tue, 03/17/2009 - 20:06
The receptionist shows up at 7:30 am Monday morning. The proctor will be there at 8:15 to escort you to the lab so just make sure you leave yourself plenty of time. It is really easy to find though so don't sweat it. Google maps will take you right there.
