SNR MobileConnect Off
Answered Question
Mar 2nd, 2009
I'm trying to demo SNR.
I think I've done all the needed config, but selecting into the Device page the Owner User ID, because the field is grey and I can't select any user.
When I try to send the call to my Remote Destination device by pressing the Mobility key, I get the following error:
MobileConnect Off
You are not a valid Mobile Phone User
Does anyone know what I must be doing wrong?
Thanks in advance.
Best regards,
Carmen
Correct Answer by testeven about 7 years 11 months ago
Hi Carmen!
With EM owner user id is grayed out. Please check if you are using Extensio Mobility. if that's the case, uncheck EM, assign a owner user id and reselect EM.
Once you do login via Extension Mobility on a phone the owner user id would change to reflect the user id of the logged in user.
Hope this helps!
Teresa.
Overall Rating: 5 (1 ratings)
Correct Answer
testeven Mon, 03/02/2009 - 05:37
Hi Carmen!
Hope this helps!
Teresa.
mcibanez Mon, 03/02/2009 - 13:40
Hi Teresa!
Many thanks for your help. You were absolutely right
Best regards,
Carmen
