03-02-2009 06:45 AM - edited 03-10-2019 04:21 PM
We are running both ACS 4.1.1.23 on a Windows Server and Solution Engine as well and are facing same issues where in the command accounting doesn't work. Can anyone pls suggest a solution for the BUG ID : CSCsg97429.
03-02-2009 10:08 AM
Yes, go ahead and upgrade to 4.1.4 build 13 to get it fixed
03-03-2009 12:51 AM
The solution is to do a software upgrade:
Farrukh
