Set dialer in a Cisco 2800 Series
Mar 2nd, 2009
Hello Folks,
we have a problem when i try to set a dialer connection in a Cisco 2800, series.
When i set the type of encapsulation in the interface bri it appears this message:
"Encapsulation not allowed on voice only interface", what does it mean?, i imagine that it's not neccesary to set the type of encapsulation into interface bri , isn't it?. Also, i can't set the dialer pool-member.
thanks in advanced
regards
Alfonso
Sitov1982 Mon, 03/02/2009 - 06:47
i forgot, the ios is Version 12.4(13r)T.
thanks
bmcginn Mon, 03/02/2009 - 08:59
  • Bronze, 100 points or more
Hi there,
You might have put the card into a voice slot. Try moving the WIC to slot 2 as I think slot 0 is only used for voice interface cards. Slots 1 and 3 are HWIC slots, slot 0 is the VWIC slot and slot 2 is the VIC/WIC/VWIC slot.
I hope that works for you!
