Employment Certification
Answered Question
Mar 2nd, 2009
After CCNA, what is the most important certification with regards to improving employability?
Correct Answer by Jon Marshall about 8 years 3 months ago
Ray
Where do your interests lie ie.
Voice = CCVP
Service Provider = CCIP
Security = CCSP
Routing/switching = CCNP
The best thing you can do is to choose based on what interests you the most. That way you become very good at what you do. And the hot topic now may not be the hot topic by the time you have certified.
Jon
Overall Rating: 4.5 (2 ratings)
Edison Ortiz Mon, 03/02/2009 - 07:26
  • Hall of Fame,
    Founding Member
If you are staying within the Routing and Switching track, the next most important certification is CCNP and the highest on that track will be CCIE.
Here are the career paths:
http://www.cisco.com/web/learning/le3/learning_career_certifications_and_learning_paths_home.html
You have to ask yourself, which career path you have the most passion for.
In addition, in order to be employable, you need to have some experience. Start by offering your services to volunteer organizations or churches.
HTH,
__
Edison.
Correct Answer
Jon Marshall Mon, 03/02/2009 - 07:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ray
Voice = CCVP
Security = CCSP
Jon
