Processor in Router
Answered Question
Mar 2nd, 2009
Hi all,
Can anybody help me in knowing what command i have to use to identify the CPU/Processor my router is using?
Please help
R.B.Kumar
Correct Answer by Edison Ortiz about 8 years 2 months ago
R.B.
In older routers, that information was clearly visible in show version. However, newer lines of routers do not display this information for competitive reasons.
With that said, CPU/Processor power isn't the only driving engine for fast throughput. Cisco incorporates dedicated ASICs in routers and switches which takes away the load from the CPU.
If you want to know how fast a router runs, I recommend checking the benchmark datasheets at this location:
http://www.cisco.com/web/partners/tools/quickreference/index.html
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
adamclarkuk_2 Mon, 03/02/2009 - 07:33
  • Silver, 250 points or more
If you mean CPU type, then :-
show version
(for just cpu output do show ver | inc CPU)
IF you mean CPU usage, then
sh processes cpu
hclisschennai Mon, 03/02/2009 - 07:38
Thanks for your reply.
But using "show version" command i am not able to see the CPU that is been used(I donot want to know about usage).
Any clues?
R.B.Kumar
Correct Answer
Edison Ortiz Mon, 03/02/2009 - 08:22
  • Hall of Fame,
    Founding Member
R.B.
HTH,
__
Edison.
