Subscriber Dump Info
Mar 2nd, 2009
Can I use Subscriber Dump Info with a Unity 4.0 to Import the information in a Unity 7.0?
Tommer Catlin Mon, 03/02/2009 - 08:14
All depends on what you are trying to do. The dump info is only going to give you things like First name Last Name, user name, extension. That's it. It will not dump out the greetings, configurations, etc.
Depending on your Unity 4.x if you are at 4.05 and higher, you can use COBRAS tool to migrate or export the database and import to Unity 7.x.
f.gouger Mon, 03/02/2009 - 08:20
I need to import Internet Subscriber from a 4.0 to a 7.0.
I try with the Subscriber dump to create a csv file and export it in the 7.0 Unity but no success.
Cobras does not import Internet Subscriber .
