LLDP + source mac address
Mar 2nd, 2009
  • Bronze, 100 points or more
Does anyone know what the source mac address of an LLDP frame should be according to the IEEE standard ?
We connected some devices that use LLDP to our network, and we noticed that they were using two MAC addresses: MAC A for ARP and IP higher layer protocol and MAC B (which was MAC A + 1) for LLDP advertisements. I am not sure if a device is free to do this.
This generates problems with our port security policy which allows only one MAC per port in the data vlan.
I only see the following solutions:
- change our policy to allow two macs/port
- ask the device manager to disable LLDP on that device
- put a VLAN ACL on all ports to drop LLDP frames (??)
- others..
regards,
Geert
Bobby Thekkekandam Mon, 03/02/2009 - 08:09
  • Cisco Employee,
Here's clause 8.2 from the 802.1AB spec:
"8.2 Source address
The source address shall be the MAC address of the sending station or port."
http://standards.ieee.org/getieee802/download/802.1AB-2005.pdf
The statement seems to assume that a given device will only have one MAC address, so using another MAC address may not necessarily be a violation.
What platform(s) and IOS version(s) are you seeing this on?
-Bobby
gnijs Mon, 03/02/2009 - 08:34
The device is a Siemens S7-300 PLC, it uses different MAC addresses for ARP broadcasts and LLDP advertisements (very strange to me, but i have a capture proving it).
It also send an LLDP advertisment every 5 seconds (not sure if this also is "within specification")
PS. What exactly does the command:
"no lldp receive" do on an interface ?
Does it filter off LLDP protocol messages (and therefore also prevents the port from learning an additional MAC address) ?
