SSH in LMS 3.01
benchj
I have LMS 3.01 running campus mgr 5.02. An earlier post said 3.1 should have CM upgraded to 5.1.1. Does this work for 3.01?
Joe Clarke
It should work in CM 5.0.2. You will need to create a campusmgr.properties in your home directory on the client. The file will contain a CMSSH line pointing to your desired SSH client. For example, if you use PuTTY:
CMSSH=C:\\putty\\putty.exe
