Cisco 1841 with additional ethernet adapter
Answered Question
Mar 2nd, 2009
I have bought a Cisco 1841 with an additional ethernet adapter (so it has 3 ethernet interfaces). But when I enter the router operative system I see only 2 ethernet interfaces, the budled FastEthernet0/0 and FastEthernet0/1. It seems that the current operative system of the router can't recognize the additional adapter. I can't find what version of the operative system or additional software is needed (at this moment the operative system is 12.4 but I can't see what specific version of 12.4). Please, can anyone help me ?
Thanks a lot.
Correct Answer by Jon Marshall about 8 years 1 month ago
Riccardo
You need to upgrade your IOS. You have 12.4-3 whereas you need at least 12.4(15)T.
Hardware support for the HWIC-1FE card was added in the T train in 12.4.
Jon
Overall Rating: 4 (2 ratings)
Jon Marshall Mon, 03/02/2009 - 09:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Riccardo
Is the additional ethernet card a HWIC-IFE ?
If so you need a minimum of 12.4(15)T for your IOS.
If you are unsure of your IOS please post output of "sh ver"
Jon
riccardo.maciocco Mon, 03/02/2009 - 09:41
Hello Jon, thanks for you response.
The configuration of my router is:
MODULAR ROUTER W/2XFE, 2 WAN S LOTS, 32FL/128 DR Modular Router w/2xFE, 2 WANs
hwic-1fe= HWIC ONE ROUTED PORT
hwic-1t= 1-PORT SERIAL WAN INTERFACE CAR
The ouput of "sh ver" is:
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SO
FTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 18:17 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
yourname uptime is 4 hours, 2 minutes
System image file is "flash:c1841-ipbase-mz.124-3i.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ1244949Y
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Riccardo
Correct Answer
Jon Marshall Mon, 03/02/2009 - 09:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Riccardo
Jon
